changing brake pads
Its not hard at all but you must be patient and use the right tools. The easiest places to really screw **** up is removing the cover to the bolt to remove the pads. Be patient with the flat tip screw driver when removing the cover, it would be very easy to strip the head off. After you remove the cover be sure to use a 5mm alan wrench to keep from stripping the bolt.
