Blowing Fuses. I want my bike back!
Old May 21, 2008 | 10:01 PM
SHugo's Avatar
Default Blowing Fuses. I want my bike back!
After having my battery explode on me, I keep blowing the 10amp Ignition fuse as soon as I turn the key to 'on'. Where do I start?
Old May 21, 2008 | 10:35 PM
jalen11598's Avatar
Default RE: Blowing Fuses. I want my bike back!
you either have an exposed wire or a short somewhere. I would start with the battery cables and trace them.
Old May 22, 2008 | 08:09 PM
redzintimidator's Avatar
def. a short somewhere. You didnt do anything else when the battery blew?
Old May 22, 2008 | 08:32 PM
SHugo's Avatar
I didn't do anything else when the battery blew.
Today my boss and I started to dig into the bike. We started with the tail and made our way as far as the coils. We examined all wires and tested each connection with no sucess. The only thing that made a difference was disconnecting the PCM.
Old May 22, 2008 | 08:40 PM
maybe you shorted out your black box then...i dont know. Something is shorted out though,...something. electrical stuff is always fun when you cant find it
Old May 22, 2008 | 08:44 PM
SHugo's Avatar
black box meaning pcm?
what we did was disconnect one thing at a time and test to see if it would blow the fuse. the only thing the didn't blow the fuse when we had it disconnected was the large black box rear of the rectifier (pcm right?)
Old May 23, 2008 | 03:53 PM
jalen11598's Avatar
Right. That is your PCM or ECU. Did you check the wires coming out of the PCM/ECU? It probably hurt to buy another one just incase. I just went to ebay and typed in "cbr f3 ECU and 13 came up. I personally like PARTSZPARTS because theybuy fully runnning F3's and stripit down to nothing and selleverything off of the bike for less.They had a couple listed for 49.99. One off a 96 and the other off a 97.
Old May 23, 2008 | 06:35 PM
SHugo's Avatar
So we did more testing today.
Conclusion is that the PCM/ECU/CDI box has an interal short, and also, I had a blown relay. I know where I can find the box, where can I get the relay?
This is it:
Old May 23, 2008 | 06:57 PM
§T®ÈÈT¿ÃÈMOÑ's Avatar
RELAY (10A)
38365-MN5-811
cost is around 20 bucks at dealer
Old May 24, 2008 | 03:25 PM
SHugo's Avatar
ORIGINAL: §T®ÈÈT¿ÃÈMOÑ
RELAY (10A)
38365-MN5-811
Thank you
tricksta1984
Oct 6, 2011 07:44 PM
Cobretticuz
Jul 30, 2011 02:16 AM
catalyst.
Sep 18, 2008 01:10 PM
jasonp
May 8, 2007 01:24 AM
bluefire7321
Feb 19, 2007 12:30 PM
