Air Filter
Old Jul 25, 2012 | 04:27 PM
Mysfyt's Avatar
Default Air Filter
Hi Everyone,
I bought my bike used and do not know what an OEM air filter would look like, or how to verify if it is. Regardless are all filters cleanable. If so what is the recommended way of cleaning it? Thanks for your time.
Mysfyt
Old Jul 26, 2012 | 01:32 AM
coalminer frank's Avatar
No! Not all filters are cleanable. Stock type paper filters are throw away. K&N, BMC, PiperCross, Uniflo Foam are cleanable. Follow the instructions. Dont use compressed air to blow cleanable filter clean. It tears the cotton/foam and ruins them. Cleanable filter usually take a special cleaner made for them. Then rinse in a soft stream of water and let air dry for a day or so then reoil them. Dont oil too much, which alot of people do. There is a fine line between too much oil and not enough.
Old Jul 26, 2012 | 12:25 PM
Mysfyt's Avatar
Thanks for the information. I see in many posts that it is usually recommended just to go with the paper filters.
Old Jul 26, 2012 | 06:27 PM
VEXD's Avatar
Adding a different type of filter can produce more airflow into your carbs, which would necessitate more fuel into your carbs to readdress the balance.
Putting a stock one back on will mean that everything is still in balance, assuming you haven't got a re-jetted bike.
I went for a K+N when I replaced mine this summer, but I bought the filter element that closely resembles the OEM part.
I haven't noticed any change in the bike's performance, but I know that means I haven't done any harm. (in theory)
I do get a slightly louder induction roar.
I'm not in awe or disappointed by that fact.
The supposed advantage of adding something like the K+N is that you only buy it once.
If you service the element correctly at the right intervals, it will probably outlive the CBR.
Turbulenz
Feb 19, 2010 05:09 PM
c_keeton600f4
Dec 28, 2009 02:43 PM
G3NESYS
Mar 12, 2008 12:25 PM
sc929
Feb 25, 2008 08:15 AM
usndocjaysin
Sep 21, 2007 10:18 AM
