98 CBR 600 F3 won't stay running
Old Sep 10, 2013 | 09:04 PM
xxSLEVINxx's Avatar
New Member
Default 98 CBR 600 F3 won't stay running
I recently just bought my old bike back from my friend that I sold it to and it wasn't running when I got it back. He has no idea what's wrong with it. I replaced a few fuses that were blown, one that he had too small of a fuse in. the rectifier went bad and started smoking so I replaced that, then had no power again. took my battery in, found out that was bad so bought a new one, now I can get it started but it will only stay running if I hold the throttle down otherwise when I let it go it will die. Also when I get to about 5-6rpm it starts to struggle. Please help, wanna get a few rides in before it gets too cold!
Old Sep 11, 2013 | 01:03 AM
gpfan1's Avatar
Sounds like you need to pull the carbs and clean them out. You're not getting onto the main jet and your idle circuit is only partially working. Choke cable probably needs to be set too.
Old Sep 11, 2013 | 07:45 AM
ambeos5's Avatar
ROTM, Oct 2014
had pretty much this same problem when i bought mine the guy had it setting outside for a while, had to clean the carbs out and run seafoam threw them for about 2 tanks and re-adjusted the idle and choke cables its runs pretty good now still loads up everyonce and a while i think i need to resync the carbs now.
ScarletCBR1789
Jan 10, 2009 04:30 PM
Tahoesa
Oct 29, 2008 04:50 PM
Markas007
Apr 23, 2008 07:29 PM
Blodgettboy24
Jan 17, 2008 08:06 PM
PHXf4i
Oct 23, 2006 10:44 PM
