97 600 f3 start button
Quick question ok having a issues with my bike starting now when i push the button i get nothing but if i jump the starter relay she fires up whats the issue do i need a new button
@No_moregixxers Welcome to the forum. The Start Switch has 4 wires to it. If you check with a meter, there should be continuity between the Yellow/Red wire and the Black/White wire when you are pressing the start button. If you don't have that, then the switch is not working. It can be dirty contacts inside, or a broken solder joint. Both are common. The switch can be taken apart to clean and repair. It's not difficult to do.
