97 600 f3 start button
Old Apr 12, 2021 | 02:55 PM
No_moregixxers's Avatar
Default 97 600 f3 start button
Quick question ok having a issues with my bike starting now when i push the button i get nothing but if i jump the starter relay she fires up whats the issue do i need a new button
Old Apr 12, 2021 | 03:29 PM
@No_moregixxers Welcome to the forum. The Start Switch has 4 wires to it. If you check with a meter, there should be continuity between the Yellow/Red wire and the Black/White wire when you are pressing the start button. If you don't have that, then the switch is not working. It can be dirty contacts inside, or a broken solder joint. Both are common. The switch can be taken apart to clean and repair. It's not difficult to do.
Georgetwn
Mar 21, 2014 04:41 AM
zombieapocalypse
May 27, 2013 11:21 PM
thecoop20
Aug 14, 2011 09:25 AM
filthy1
Aug 14, 2010 07:55 PM
mikemcw
Apr 26, 2009 08:00 PM
