Start button
Old Apr 25, 2009 | 03:22 PM
mikemcw's Avatar
Default Start button
Ok so when I go to start my bike, I push the start button and I get nothing. The horn works and the lights are on but I get nothing from the starter. This only happens once in a while. What is my problem?
Old Apr 25, 2009 | 04:44 PM
MrBomb's Avatar
first thing i would do is take the cover off the switch and make sure all the wires are soldered onto the switch good
Old Apr 25, 2009 | 05:11 PM
f3BikeR's Avatar
emergency stop button is "on"?
Old Apr 25, 2009 | 05:12 PM
A4wheelin's Avatar
Can you hear the starter relay switch "click" when you hit the starter button?
Old Apr 25, 2009 | 10:10 PM
mikemcw's Avatar
The kill switch is in the operation position. No when I push it i get nothing. No noise nothing. Im thinking maybe a short some where or like mentioned above the wire connections.
Old Apr 25, 2009 | 10:25 PM
f3BikeR's Avatar
Is your neutral light on ? If not, then the sensor or its wire is bad. Pulling in the clutch in that case should help, assuming that its sensor is working..
Old Apr 26, 2009 | 06:25 AM
mikemcw's Avatar
I always start it in neutral. So that is not the problem unless a sensor is bad and miss reading. Should I have to pull in the clutch because I dont have to.
Old Apr 26, 2009 | 08:00 PM
I've had 2 things cause that problem intermitently. Dirty contacts on the Engine Stop switch, and dirty contacts on the actual Starter switch. It's not too diffucult to take it apart and clean the contacts.
brikacid
Nov 7, 2011 11:24 AM
hmm
Sep 28, 2011 02:52 PM
Ghostrider600
Sep 14, 2009 12:05 PM
Ghostrider600
Sep 12, 2009 05:52 PM
abelg
May 27, 2009 04:36 AM
