What is best front end conversion?
Old May 8, 2009 | 06:28 PM
rothjl749's Avatar
Default What is best front end conversion?
I have done a lot of searching and can't find any definite answers to my question. What would be the best front end conversion for my 91 F2? My definition of best would be the following:
1. - The latest technology
2. - Minimal modifications
3. - Inverted forks
4. - Better brakes
Any input would be greatly appreciated.
Thanks,
Josh
Old May 8, 2009 | 07:42 PM
Browntowns20s's Avatar
do you mean 91?
Old May 9, 2009 | 05:06 AM
CaliKush's Avatar
hahah i think u meant 91...i'd go to f4i conversion.. thats basically the newest cbr.
Old May 9, 2009 | 07:58 AM
rothjl749's Avatar
Oops, yes I meant to say 91. I also should have said that I would like to replace the front end in example; the forks, brakes, and triple tree. That type of front end.
Old May 9, 2009 | 08:36 AM
Viking's Avatar
The easiest is to go with an F3 conversion as this has the next generation dampers (with rebound adjustment). The fit is one to one.
However, there is one problem: the F2 has a cable speedometer.
Although it is possible to replace the entire front with better brakes and so on, you will loose the speedometer.
Old May 10, 2009 | 03:14 AM
CaliKush's Avatar
there is a thread on how to convert ur gauge to a f4i digital gauge
Old May 10, 2009 | 06:45 AM
rothjl749's Avatar
How hard would an 03 R6 front end be? I found one for $150. Any idea? The bike came with the f4i gauge already. The only thing on the gauge that doesn't work is the coolant temp.
Old May 10, 2009 | 11:20 AM
ecd2004's Avatar
the problem that youll have is that the f2 has a cable speedo, the f3 does not, you have to run it off the transmission (i believe i could be wrong) on the f3 but the f2 engine wont allow for that. their is a stickied thread on how to use the f2 front wheel and thats your best, most hassle free bet.
Old May 10, 2009 | 11:33 AM
Sand.Man's Avatar
If you don't know anything about steering geometry, rake angle, etc... And you don't know how to machine parts, don't bother.
It's not as simple as bolting on a different set of forks and calling it a day (F3 is direct fit, but as mentioned you lose the speedo).
catworst
Alternative Parts
Feb 21, 2021 02:03 PM
CBARE
Jul 23, 2011 11:02 AM
polarpanther
Apr 27, 2011 01:28 AM
chuckd
Aug 4, 2009 09:37 PM
MikeMirage
Apr 26, 2007 10:47 PM
