Spark Plug replacement
Old Jul 28, 2009 | 01:41 PM
NYKnick1015's Avatar
Default Spark Plug replacement
Noob question but how does every one change their spark plugs on their f2?? do you do it thru the door or do you take the tank off? I was told thru the door but i guess my hands are too big to fit in that small space so i was looking for an alternative method.
Old Jul 28, 2009 | 02:21 PM
Ralph's Avatar
Hey, I've change mine a couple of times and I go through the doors. Yeah real tight fit but that's how I did it. Lots of patience and slow movements. Keep in mind you can do most of the turning by hand. I'm new too and it took about an hour to take the old ones out and replace and yeah my hands are regular sized lol.
Patience is the key,
Ralph
Old Jul 28, 2009 | 02:35 PM
Dissevered's Avatar
I do it through the door as well, very tight fit. If you really do have large hands then I am not sure if it is easier to take the radiator and fan off and get them from the front, or the gas tank/air box/coils and get them from the top.
Old Jul 28, 2009 | 03:14 PM
Sand.Man's Avatar
I have big metalworkers hands, you just need to drop the socket/extension down the hole before you put them on the wrench.
Old Jul 29, 2009 | 01:30 PM
g32bturbo's Avatar
that's what the doors are for, but i took the whole fair off each side.
Old Jul 29, 2009 | 06:56 PM
fastrax203's Avatar
I took the doors off, but took the tank/airbox off for easier access. Took about 30 minutes to 45 minutes.
Old Jul 29, 2009 | 09:03 PM
shardoflard's Avatar
i use the doors.
i have very large hands as well.
it only takes me around 5 minutes and my hand comes out raw every time.
Old Jul 30, 2009 | 09:45 AM
Ian's Avatar
Ian
I had the fairings off and the tank off towards the back, but I did my plugs, air and fuel filter, oil and oil filter all at the same time. The plug second from right was a bear to get to, I don't know how this is done coming in through the access doors, very tight fit I guess....
-Ian
Old Jul 30, 2009 | 02:27 PM
it is a very tight fit...
but changing these plugs is easy compared to other bikes..
u guys need to quit your whining and man up and do a little work...
Hyena
Jan 14, 2013 11:17 AM
NOSTUPIDZONE
Jul 12, 2007 08:05 PM
BlueWheelies
Mar 12, 2007 01:13 PM
mccannf3
Dec 4, 2006 10:40 PM
allnath3
Nov 5, 2006 12:31 PM
