Spark Plug Replacement
Old Mar 10, 2007 | 10:52 PM
BlueWheelies's Avatar
Default Spark Plug Replacement
Hey,
I am about to replace the plugs on my 93 RR for the first time. I did the plugs on my old SV650, and it was pretty straight forward, are there any tricks I need to know before I do the replacement on the 900RR?
My perception of the process is 1)take the tank off 2)take the airbox out 3)pull out the plugs 4)install new plugs
Is this more or less what I will be doing?
Thanks for the help
Dave
Old Mar 11, 2007 | 12:15 AM
johnnyh's Avatar
Default RE: Spark Plug Replacement
10-4 don't forget the antiseize on the treads. It will save the head treads. Johnny
Old Mar 11, 2007 | 03:02 AM
batman911's Avatar
What kind of plugs are you guys using? I haven't had my 900rr for long and am planning on changing the plugs pretty soon.
Old Mar 11, 2007 | 08:25 AM
DevenJames2005's Avatar
I use ngk plugs. I have a 95 and the pluge were a bitch to get to because the way they are positioned in the head, I got them out no problem after I used a swivel extention and a universal on the ratchet. I dont know about a 93, but the attachments helped me out to get it the tight spot. Try to make sure the plugs are gapped correctly also.
Old Mar 11, 2007 | 07:22 PM
batman911's Avatar
I mean which plugs... On my fzr and my yzf I use NKG cr9... What ones do you use on 900rr's???
Old Mar 12, 2007 | 10:23 AM
chrisf's Avatar
I run NGK Iridiums (CR9EHIX-9). But if these things get wet, they are pretty much done. I think they cost me $35 or so for a set.
Old Mar 12, 2007 | 11:32 AM
batman911's Avatar
Not sure that would work for me... I don't have a garage... so my bike spends its nights outside under a bikecover and tarp...
Old Mar 12, 2007 | 11:44 AM
chrisf's Avatar
I'm talking bout wet from fuel. If you get rain on your sparkplugs, there are much more serious issues at play.
--Chris
Old Mar 12, 2007 | 01:13 PM
batman911's Avatar
ooohhhh.....
Hyena
Jan 14, 2013 11:17 AM
NYKnick1015
Jul 30, 2009 02:27 PM
NOSTUPIDZONE
Jul 12, 2007 08:05 PM
mccannf3
Dec 4, 2006 10:40 PM
allnath3
Nov 5, 2006 12:31 PM
