Should their be play in the front sprocket?
Old 04-30-2011, 10:57 AM
underground-mpyre's Avatar
Default Should their be play in the front sprocket?
I am finalizing my build and got a quick question. Should their be a little play from side to side from the front sprocket? I am talking slight play between the bolt and the block.
Old 04-30-2011, 03:19 PM
drzed1980's Avatar
i'd say no
Old 04-30-2011, 03:32 PM
DagonRais's Avatar
How much is a little
Old 04-30-2011, 04:06 PM
HenryM's Avatar
THe front sprocket on my 1KF has about 1mm of float between the engine casing and the bolt. The same question went through me head when I fist removed the sprocket and refitted a new one. The old one was the same so when the new one had the same play I didn't worry about it.
Two years of riding it says it doesn't matter.
If you remove the sprocket, just make damned sure you torque it back down correctly. No way you'd want that to come loose. No way you'd want to break it off either.
Honda recommend renewing it when you replace the sprock. Food for thought!
Old 05-01-2011, 08:54 AM
Ya, 1mm sounds right, Henry. I am going over everything and run across that and didn't seem right. I feel better now.Thanks
Old 05-02-2011, 01:01 PM
adrenalnjunky's Avatar
yep - that play is normal. I even think the Clymer manual references that play as normal. Torque the bolt holding the sprocket on to 40 ft/lb and you're good.
Ls1Mx5
F2 Tech
01-05-2013 05:54 PM
ssweetbro
04-28-2010 06:01 PM
White22
03-10-2010 10:22 PM
oldschoolsdime92
03-07-2009 08:11 PM
Quick Reply: Should their be play in the front sprocket?
