Front sproket play?
Old Apr 27, 2010 | 05:27 PM
ssweetbro's Avatar
Default Front sproket play?
So I am concerned. Can anyone give me any pointers? I recently did a 520 swap on my F4i. So I took the bolt for the front sprocket off(it came off pretty easy, compared to other bikes I've worked on) and then I put the new one on. When I tightened the bolt back down, there was some play in the sprocket left and right. Like, the bolt was tight, and I could move the sprocket left and right no the splines, like, half a millimeter. I was concerned, so I put the stock one back on, and it had the same play. Is that just normal? Anybody had this problem before?
Thanks
Old Apr 27, 2010 | 09:58 PM
vangill's Avatar
July 2010 ROTM
yeah its gonna have a little play, not a TON but a little
Old Apr 28, 2010 | 05:56 AM
chetman7's Avatar
since we're already on the subject of front sprocket....what should that front sprocket be torqued down to?
Old Apr 28, 2010 | 08:57 AM
DBEAU's Avatar
A few quick google searches are showing 40 ft\lb.
hopefully someone can confirm this, I don't have access to my manual here at work.
Old Apr 28, 2010 | 06:01 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Yeah, the Driven counter sprocket had a little play in it too. 40 ft./lbs. is correct torque.
GILL
Feb 11, 2010 10:46 PM
Hayden06F4i
May 3, 2008 09:35 PM
mltorres
Feb 11, 2008 06:30 PM
Draco88
Nov 2, 2006 04:09 AM
italinstalin
Sep 15, 2005 12:48 PM
