replaced clutch, still slipping
Old Mar 28, 2008 | 12:24 PM
GARMIN1000F's Avatar
Default replaced clutch, still slipping
I have replaced the clutch on my bike with a kevlar clutch, replaced the steels and the springs used valvoline 4 stroke motorcycle oil for wet clutches.
damn thing still slipps in high rpm. seems to be ok in lower rpm but when i really want to get on it the damn think just slips till i let off again.
Old Mar 28, 2008 | 05:03 PM
elmer's Avatar
Default RE: replaced clutch, still slipping
back off the adjuster maybe?
sorry, thats all I got.
Old Mar 29, 2008 | 02:29 AM
amig's Avatar
are you sure you have all the parts?
when i was troubleshooting my clutch i was missing a huge washer behind the clutch basket, which caused the slippage, only a $10 fix but i ended up replacing the whole clutch shouldve looked more carefully next time. wouldve saved me $200
Old Mar 29, 2008 | 12:25 PM
yea im pretty sure i have taken this thing apart like 10 times with the manual right with me. the new kevlar clutch i put in is all ate up. chunks of fiber missing, the steels you can tell were spinning against the fibers. I cranked the springs all the way down and loosened the clutch cable all the way but it still spins.......
Old Mar 29, 2008 | 01:46 PM
Sand.Man's Avatar
Remove 1 spark plug, should be enough to keep it from spinning
Old Mar 29, 2008 | 01:57 PM
amig's Avatar
by cranking the springs down i hope you mean to the specs in the manual its something like 9nm of torque or something like that
idk why you would have chunks missing, but did you soak everything in oil? cause youre supposed to
maybe pics might help?
dyenasty18
Jul 3, 2010 09:13 AM
vitaminB18
Dec 13, 2009 11:39 PM
adams_CBR600f2
Jun 25, 2009 02:46 PM
busyychild
Oct 11, 2007 10:55 PM
HighRevver
May 30, 2006 06:36 AM
