Wider tire = higher pressure?
I'm a tire expert. Usually the Tire Pressure on the sidewall of the tire is the maximum pressure you're allowed to put. I would recommend putting 5psi lower than the tire pressure on the sidewall. If you notice cars, they have a maximum of 45psi. Our policy recommends 32 psi as when you're tire heats up the psi in the tire increases. On colder weather situations, 35 psi should be put into affect.
You have my advice. You're choice.
-Jasper
-Jasper
ya the sidewall pressure is the max like jahnaboi said, just put in what is recommended in your manual, I know a lot of guys on here drop it a few psi when they are carving up the twisties too
ORIGINAL: duplago
use whats on the tire and why would you put a bigger tire on? Your handling is gonna be adversly effected.
jahnaboi - I just checked the tire. It says max load 42 psi when cold. I guess that's the same as the standard 160 tire. How come the manual says 42 psi on the rear tire when that's the recommended max load? Should I go for 37 psi anyway?
