Poor fuel mileage
Old 05-21-2008, 05:51 PM
Clorox09's Avatar
Default Poor fuel mileage
I have a 91cbr with 33,000 miles on it. My bike is only getting about 39 miles per gallon highway at the momment. I also dont have consistant power. it is due for a valve adjustment but wasnt sure if anything elsei should look at ... coils are good tested... didnt know if there was any chance timing chain maybe?
Old 05-22-2008, 11:21 AM
Default RE: Poor fuel mileage
Sync the carbs. I build a carb sync tool for around $40. I have yet to test it. I am rejetting the carbs. I get about 35 miles a gallon right now. Carbs are mostly synced but i have no fairings and it seems to run rich. I do now know the quality or if the jets currently installed are correct, hence the replacement. Its only $40 for the jets (which I have) and a couple hours work. We'll see what happens when I am finished.
Old 05-22-2008, 09:09 PM
Clorox09's Avatar
i've done it already i have the carbtune 2 so it was good
Old 05-23-2008, 07:20 AM
redzintimidator's Avatar
39 doesnt seem too bad...Try running some seafoam in the gas tank to clean the carbs and carbon deposits from the valves and piston heads.
Old 05-23-2008, 09:40 PM
elmer's Avatar
Thats pretty close to expected fuel mileage. I'd go ahead and just pull the carbs and clean each jet individually. Search the HowTo forum for a carb cleaning howto for some help. If you plan on adjusting the valves I'd go ahead with that, it won't hurt anything if done right.
Good Luck!
curley444
09-05-2010 12:24 AM
Thepoweroflard
04-26-2010 10:45 AM
brandon k
09-25-2007 09:47 PM
transamlt1man
04-23-2007 10:26 PM
jorge13
04-08-2006 07:42 PM
Quick Reply: Poor fuel mileage
