poor gas mileage
RE: poor gas mileage
so other than poor gas milage and being a lil slow to accelerate, how does she run?
can you still do lets say 100mph + ?
maybe your fuel pressure regulator is bad!
maybe your injectors are stuck open !
maybe you didn't plug the connectors to all your spark plugs in!
maybe one of your sensors are disconnected ...... ie map sensor tp sensor.
I'm betting one of those sensors are disconnected!
the bike will still dowell over 100 i plugged the coils in checked for open connectors but the fuel pressure regulator leaks fuel from the vacume hose when i pulled it off is that normal and the gas was not very clean looking when it came out the bike did sit for a while like three years how do you check to see if its good
