Poor Gas Mileage and Performance
Old Apr 25, 2010 | 04:50 AM
Thepoweroflard's Avatar
Default Poor Gas Mileage and Performance
I recently did a valve lash adjustment and replaced the head gasket on my 92 F2. After reassembly, the ticking was gone but I started having performance issues. The bike loses power on acceleration usually in the mid range and is getting very poor gas mileage. I had a little bit of an issue with it bogging out on hard acceleration before but not anywhere near this badly and I was getting 40MPG before this as well.
Any ideas as to what could be the issue?
Also, I'm not sure if this could be related but my dumbass got the ignition coils mixed up when trying to reassemble. Anyone have any good tips on identifying which one goes to which cylinders and the symptoms it would exhibit had I done it wrong?
Old Apr 25, 2010 | 10:25 AM
Sand.Man's Avatar
If you've got the plug wires crossed up, that will cause very poor fuel consumption and very very poor running conditions.
If you suspect that this is your problem, start with the plug wires.
You should feel special, I made this diagram juuuuust for you
Old Apr 25, 2010 | 12:54 PM
jnicola's Avatar
A valve adjustment will also potentially throw your carbs out of sync. First valve adjust, then carb sync usually.
Old Apr 25, 2010 | 04:32 PM
Thanks mates. I'll check out both.
Old Apr 25, 2010 | 05:18 PM
Preid's Avatar
I get atleast 50mpg, usually 55mpg with motorway and city driving.
Just thought Id throw that out there. Hope you get it sorted.
Old Apr 26, 2010 | 02:15 AM
It looks like it was a leak on the intake side. I readjusted and tightened the clamps around the intake boots and it's running fine. Thanks for the help guys!
Old Apr 26, 2010 | 10:15 AM
ljung's Avatar
55 mpg? I get around 34 mpg (0.7 liters/10kilometers) Must be some serious wrong over here :>
Old Apr 26, 2010 | 10:45 AM
halffast1g's Avatar
depends on how you ride too
curley444
Sep 5, 2010 12:24 AM
Mik76
Jun 5, 2010 11:35 AM
Pacs_Legend
Jun 5, 2006 06:01 PM
jorge13
Apr 8, 2006 07:42 PM
zflcz04
Mar 3, 2005 10:42 PM
