Oil change
Old Apr 19, 2006 | 09:41 PM
gride99's Avatar
Default RE: Oil change
great instructions man, this is exactly what I needed because I need to change the oil in my bike and Im an not mechanicly inclined at all, so this will be a huge help. thanks
ORIGINAL: Nick I.
1. remove fairings. (drain plug is on the shifter side)
2. place oil pan under the drain plug.
3. remove drain plug, empy oil, replace plug.
4. cover exhaust with aluminum foil.
5. place oil pan under the filter. (filter is on the brake side)
6. remove filter, oil will get everywhere.
7. lightly coat rubber seal on new filter with clean oil. (clean surface where the filter seats)
8 install new filter, tighten, do not over tighten.
9. fill with 3.7qts of the fresh stuff. (dip stick is above rear brake lever, kinda.)
10. clean up the mess.
11. start the bike, check for leaks.
12. shut it off, let the bike sit for a few minutes, check the oil level.
13. reinstall the fairings.
14. go ride!!
Old Apr 22, 2006 | 04:29 AM
MT Wallet's Avatar
Hey all I'm new
I changed the oil in my '92 f2 couple weeks ago.
I needed a special tool to take off the filter, filter wrench...it was on tight.
Also, I overfilled it...even though my f2 book says 4 qts of oil...it was less than that.
Maybe go to three qts and adjust accordingly?
I also took off the right side lower fairing. Good luck
Old May 1, 2006 | 06:06 PM
92CBR's Avatar
hey guys im doin my oil tonight.....just a Q from a canadian guy.....3.7quarts i believe is 3.5 litres.....confirm?
thanks!!
Pete
Old May 1, 2006 | 06:54 PM
MT Wallet's Avatar
I can't do the conversion, sorry.
Bump!
Old May 1, 2006 | 09:21 PM
92CBR's Avatar
i figured it out!! thanks everyone!!
Pete
Old Jun 29, 2006 | 12:56 PM
spencerjw's Avatar
Just in case any of our other friends from the north ask this question...
You are correct: 3.7 quart [US, liquid] = 3.501 liters
Old Jul 5, 2006 | 07:19 AM
mikequinn's Avatar
If you can afford it use fully SYNTHETIC OIL, you bike will thank you in the long run
It' will run for Smiles & Smiles & Smiles
Old Oct 17, 2007 | 06:52 PM
jalate compa's Avatar
Default oil question???
hi does anybody know how much oil do i need to render in my cbr600 f21992??? thanx
Old Oct 17, 2007 | 06:55 PM
Default RE: oil question???
thanx guys i preciate your help
Old Oct 19, 2007 | 06:32 PM
FNQuickF2's Avatar
ORIGINAL: jalate compa
Just over three and a half quarts.
RB
stealthCBR929
May 24, 2012 03:15 PM
89HurricaneF1
May 7, 2012 09:52 PM
michealparks
Feb 10, 2010 12:16 PM
fiveoh
Jul 8, 2008 10:43 AM
otisdr
Aug 7, 2006 06:51 AM
