Oil change
Old Apr 18, 2006 | 12:15 PM
richterat83's Avatar
Default Oil change
Alright, i'm not a bike mechanic, and, never claimed to be so, don't shoot me for askin. It's just that's its almost time to do an oil change, and, was wondering how I go about doing it. I had ordered a manual for the bike, but, it wasn't a service manual, it was just a list of all the parts. So, if anyone's done thier own oil change on an F2 or 3, is it difficult? I change the oil in my cars myself, and, i've got most all the tools needed here at my office, so, any advice is needed and much appreciated. I don't even know where to start. I've always had my bike taken into the shop and had them give it a once over, but, money is getting tight right before my move, so, i'm gonna try it myself. Thanks in advance for any help
Tylor
Old Apr 18, 2006 | 01:09 PM
Funedude05's Avatar
Default RE: Oil change
Hey, first of all, nice F2. I changed the oil in my '94 f2 once, so i'll see if i reemmber how. it's basically just like a car. drop the plug , drain the oil, take off the filter, new one in with the oil on the seal, then fill er back up. But i do remember running into a few problems. one was i had to find a pretty low container to let the old oil drain into, my regular car one wouldn't slide under. I tried to get the oil filter off just by going in under the radiator from the front but it was a tight squeeze, and i couldn't get a good angle to work. i ended up removing one of my fairings enough so i could get in from the side. i didn't take it all the way off, but if i would have i'm sure it would have been easier. oh yeah, a good oil filter wrench would help also. that's all i can remember, but it was a while ago that i changed the f2's oil. hope that helps some.
David
Old Apr 18, 2006 | 01:45 PM
Leif's Avatar
funedude05 is right on. i would go ahead and remove your lower fairings, so yu can get to the filter easier. let the bike run for about 5-10 minutes just to get it warm. turn it off then remove the drain plug, and filter. as a funny side note make sure you put the plug back in before you put oil back in the bike. we had a messy accident last weekend that way. and yes the clearence under the bike is too low for most oil pans. what we did was cut off a bucket and slid it under the bike, then drained it into the normal oil pan. hope that helps.
Old Apr 18, 2006 | 04:51 PM
Sounds good. I havn't really even gotten down under the bike to take a look where the filter and plug are at yet. I feel like such a newbie[&:]
Thanks for the heads up on the oil pan and pulling the plastics off. Also, does the bike need to be straight up and down, as in on a paddock stand or center stand? Or, can it be on the kickstand? I know you're supposed to have it straight up and down when filling the oil back up. Thanks again in advance.
Tylor
Old Apr 18, 2006 | 06:32 PM
rrasco's Avatar
on my f1 the drain plug is right where the headers start to curve up to get to the block. you said you change the oil on your cars, so you cant miss it, its the only thing even closely resembling a drain plug.
[IMG]local://upfiles/5310/34B797F12FB442F3A7E6420F61427735.jpg[/IMG]
Old Apr 18, 2006 | 09:13 PM
Nick I.'s Avatar
1. remove fairings. (drain plug is on the shifter side)
2. place oil pan under the drain plug.
3. remove drain plug, empy oil, replace plug.
4. cover exhaust with aluminum foil.
5. place oil pan under the filter. (filter is on the brake side)
6. remove filter, oil will get everywhere.
7. lightly coat rubber seal on new filter with clean oil. (clean surface where the filter seats)
8 install new filter, tighten, do not over tighten.
9. fill with 3.7qts of the fresh stuff. (dip stick is above rear brake lever, kinda.)
10. clean up the mess.
11. start the bike, check for leaks.
12. shut it off, let the bike sit for a few minutes, check the oil level.
13. reinstall the fairings.
14. go ride!!
Old Apr 19, 2006 | 09:53 AM
ORIGINAL: Nick I.
14. go ride!!
What is the reason for covering the exhaust with aluminum foil?
Tylor
Old Apr 19, 2006 | 11:14 AM
Nick I.'s Avatar
when you take the oil filter off it will drip all over the exhaust. cover them with foil, or whatever so it is less of a mess and you don't get oil on the pipes.
Old Apr 19, 2006 | 12:07 PM
Doh, sorry, i'm really not all here today. I don't know why, but, I was thinkin that you meant to put the foil on the can. I am really really tired, please bare with me. But, now that I see you mean to put it on the header near the filter, that makes sense. As I said earlier, i havn't gotten down under the bike yet to even look. I'm just trying to see what to expect before I get down there. Thanks again guys
Tylor
Old Apr 19, 2006 | 12:12 PM
Nick I.'s Avatar
no problem, once you get the plastics off and take a look at everything it will all make sense.
