Meet my 1994 CBR600F2
Old Oct 7, 2017 | 02:54 PM
  #41
Rybo's Avatar
Okay the full airbox must have sold already...what terrible luck. I found this and bought it instead:
It looks slightly different than what you posted, Gunk. What is the large box in the upper right?
Old Oct 7, 2017 | 03:04 PM
  #42
Gunk's Avatar
It’s an air filter
Old Oct 7, 2017 | 03:32 PM
  #43
Rybo's Avatar
Ahh, that makes sense. But what doesn't is why is it only on one side??
Old Oct 7, 2017 | 04:09 PM
  #44
Gunk's Avatar
No idea!
Old Oct 7, 2017 | 11:41 PM
  #45
Rybo's Avatar
It's nice to have some good news once in a while. I finally got around to pulling all the jets and I've confirmed that at some point the bike was rejetted to a smaller jet for the altitude. Whether or not it was done professionally and whether or not they're the perfect jets, I dunno. But they're smaller than OEM which means someone at least got it somewhat right. They actually weren't as dirty as I expected but there was definitely some pilot jet clogging.
I can't wait to see how well it runs with the carb all cleaned out and with the proper airbox configuration!
Old Oct 7, 2017 | 11:42 PM
  #46
Rybo's Avatar
Oh and for reference:
Carb 1: 125, 40
Carb 2: 128, 40
Carb 3: 128, 40
Carb 4: 125, 40
Old Oct 8, 2017 | 12:42 AM
  #47
CaBaRet's Avatar
Hi matey, is your bike going to be used at altitude a lot, and what type is your ICM ,did the PO put on a new loom and ICM ,as you can see the solenoid has a connecter to be plugged into the loom, along with the TPS on the carbs
Old Oct 8, 2017 | 12:50 AM
  #48
CaBaRet's Avatar
That filter performs a different function to the other
Old Oct 8, 2017 | 02:51 AM
  #49
Rybo's Avatar
I forgot to check out the loom in depth but I do recall that I have an unused connection on the right hand side of the bike. He must have replaced it because the TPS does indeed have a connection in the housing in front of the battery.
And yes, I live at high altitude. The average altitude of my commute is about 6,500 feet (just shy of 2,000 meters) above sea level.
Old Oct 8, 2017 | 05:18 AM
  #50
CaBaRet's Avatar
Hi, good there should also be a connector for the air solenoid, also take a look at the jets for high altitude
