I know this is a noob question
Old Nov 27, 2007 | 02:10 PM
dawoonj's Avatar
Default I know this is a noob question
How do you push start the bike? I had to let my bike sit for the past two weeks because I was moving. But now, the bike won't start. So, I figured the battery is dead. I can see the headlight getting dimmer and dimmer with each attempt.
Do I just run along side it, jump on and hit the start button??
Old Nov 27, 2007 | 02:20 PM
redcbrman's Avatar
Default RE: I know this is a noob question
Should be a clutch/gas process. When rolling (have to have some speed) release the clutch and apply gas at the same time. Its a timing thing, I do it in my car every once in a while just for fun.
Old Nov 27, 2007 | 02:49 PM
baja74vw's Avatar
Be careful while doing this!!
Turn your key on, make sure the kill switch is on run. Put your bike in gear. Sometimes a higher gear is better. Make sure the kickstand is up. Hold in the clutch and start pushing the bike. Get your speed up, hop on and release the clutch.
Or just charge the battery. Good luck.
Old Nov 27, 2007 | 03:40 PM
MikeInCtown's Avatar
I'm 6' so this works for me.
Set choke full on..... Clutch in.... Click into first gear..... turn key to run position.... use both feet like Fred Flintstone and get moving, maybe to about walking speed, or just a little better.... Dump clutch.
My bike almost always started on the first try within a half second that way. The only times that didn't work, the bike was hot and I started with no choke on, but gave a little gas.
Old Nov 27, 2007 | 04:13 PM
Mr Pink's Avatar
I recommend starting in 2nd gear. First is too low. Get it rolling and dump the clutch. Did mine about 2 weeks ago.
Old Nov 27, 2007 | 09:44 PM
KRUSHER F3's Avatar
ORIGINAL: Mr Pink
I agree second is better in that it will less likely slide the rear wheel than first will. I had to push start mine 2 weeks ago when my regulator/rectifier went out and starter would barely turn. Iturned the key on, put it in second, got it rolling, hopped on and popped the clutch and it started right up, but it was already hot. If the weather is cold and the engine is cold you might have to do a lot more pushing, unless you live near a hill.
Mario072
Jul 29, 2011 04:57 PM
CBRockin
Dec 22, 2010 08:06 PM
S2005
Jun 11, 2010 08:59 PM
Vanandt71
Jul 29, 2009 07:40 PM
jersey8
Dec 16, 2007 11:19 AM
