how to replace headlight?
Old Nov 2, 2008 | 09:33 PM
HBcarnut's Avatar
Default how to replace headlight?
as the title says Thanks ina dvance
Old Nov 5, 2008 | 09:23 AM
Rickracer's Avatar
Default RE: how to replace headlight?
The bulb screws into the back of the housing. You may need to pull your instrument panel to access it. [8D]
Old Nov 5, 2008 | 10:23 AM
Sand.Man's Avatar
You can reach up under the nose of the bike to change it out, but you have to know how it comes off.
Old Nov 6, 2008 | 03:22 AM
eweppley's Avatar
There isa plastic peice right below the headlight assembly. Take that off (two plastic pull pins). Now reach up under the headlight from the front and pull back the rubber boot covering the plug and bulb. Open the spring clip and release the bulb from the rest of the headlight assembly. Voila. Thehardest part about the whole thing is lining thetabs up andputting theheadlight backin withoutbeing able to see it very well. You can look at it or touch it, but notboth at the same time...lol. I can't remember exactly, but I think it's easier to put the bulb in the assemblyfirstand thenplug it into the socket. Hope thishelps...
Davidth93
Jul 16, 2009 12:22 AM
A4wheelin
Apr 21, 2008 02:57 PM
rdsii64
Aug 15, 2007 05:24 PM
cyber00677
Aug 3, 2007 03:57 PM
BlindLOKI
May 27, 2006 02:37 AM
