HELP!!! Voltage dropping when ignition is turned on
Old Aug 16, 2008 | 07:49 PM
gnuwolf's Avatar
Default HELP!!! Voltage dropping when ignition is turned on
I checked the voltage between the terminals off the battery before i turn the ignition on and it shows 12.x but when I turn the ignition on, it will quickly drop. 11.x to 10.x then i turned the ignition off since i don't want to get my battery drained.
I did a leakage test and it show 0.05 mA.
Could it be the battery? or a bad wiring?
Old Aug 16, 2008 | 08:10 PM
edwardtn's Avatar
Default RE: HELP!!! Voltage dropping when ignition is turned on
Seems normal to me, when you turn the ignition on there is a draw on the battery. If the bike were running (higher than 3k RPM) I would expect the voltage to be 12-14v...are you having problems keeping your battery chargerd?
Old Aug 16, 2008 | 08:35 PM
gnuwolf's Avatar
ORIGINAL: edwardtn
Yes sir. Voltage won't go up more than 13.5 even if I rev it up to 2.5K RPM.
Old Aug 16, 2008 | 08:57 PM
edwardtn's Avatar
well, you don't want the voltage to be higher than 12-14 with it running. That would be indicative of a bad regulator rectifier. If your voltage is 13.5 with it running that is a good thing. But, if you battery is not holding a charge get it tested. Bike batteries don't last long.
Trips
Jul 5, 2010 05:21 PM
Drekk
Jan 27, 2010 05:59 AM
kschlett
May 1, 2008 02:42 PM
OH OH 929
Sep 6, 2006 02:40 AM
crucialfate
May 7, 2006 03:39 PM
