the mod: extra ground for regulator?
Old Aug 16, 2008 | 08:12 PM
SalemCBR's Avatar
Default the mod: extra ground for regulator?
I've noticed when I ride my 92 f2 and I'm not high in the rpms.... say there is traffice and I don't get over 3k rpm. When I stop then go to restart the bike the batery is dead. I push start it and I don't see the problem again until I've sat in traffic and stoped and started it.
Basicly I'm thinking this would be the signs of a bad regulator. But back when I was active on the forums more I remember it being said from a honda tec that the ground for the regulator was too small. So, it was suggested to run a ground from a regulator bold to a solid and sanded part of the frame. Do people still suggest this?
I know probably what I need to do is a volt test on the battery but thoughts still.....
I'd also heard that if the bike isn't over 3k then the stator isn't charging the battery.
Old Aug 16, 2008 | 09:04 PM
edwardtn's Avatar
Default RE: the mod: extra ground for regulator?
It's true that the stator does not charge the battery at idle. I have not heard anything about modifying the OEM RR, but as soon as it burns out I would replace it with an aftermarket RR, or a GSX-R RR...for better heat dispersion. You can test your RR to make sure it isn't frying your battery (causing it to discharge)...but you may just need a new battery. (you can have that tested too at an autoparts store).
banthony45
Feb 17, 2012 07:21 AM
coldflood
Aug 13, 2011 09:22 PM
woo545
Dec 24, 2008 02:09 PM
blaster
Nov 7, 2007 02:07 PM
Sproutf3
Jun 20, 2007 02:48 PM
