headlight wont turn on
Old 01-13-2009, 08:55 PM
halffast1g's Avatar
Default headlight wont turn on
I bought the bike from my neighbor, its a 92 f2. He said the light flickered on and off a lot, so he replaced the bulb, and it kept doing the same thing. he said one day he turned the bike on and the light didn't work again. I will be getting a repair manual soon, but wondered if any of you guys had some direction for me to go in.
I also replaced the starter switch assembly on the right handlebar, the bike runs like a champ and starts up first click!
update: I'm going to run a wire from the positive on the battery to a fused switch, then to the headlight power wire. My manual still is not here, does anybody know which wire is the power on the headlight? Any reason not to do this?
Old 01-13-2009, 09:20 PM
Sand.Man's Avatar
Default RE: headlight wont turn on
Headlight turns off when the starter switch is pressed, check the wires around there.
Also check the highbeam switch and wires.
And any wires/grounds leading to the headlight.
Other than that, I can't think of anything.
Old 01-13-2009, 09:22 PM
halffast1g's Avatar
The highbeam lights and everything are fine. The headlight is permanantly off :-(. I wonder if there is a ballast or something for the light. I'm gonna have to get out the voltage meter again
Old 01-13-2009, 09:28 PM
I would get out ye olde volt/ohm meter, and a wiring diagram. there should be a headlight interrupter that shuts the light off when you push the starter button, my guess is its bad.
Old 01-14-2009, 01:57 AM
Duck187's Avatar
The starter switch on my bike caused my headlight not to come on once. Come to find out it was my starter switch!Cleaned the contacts and fixed it.BUT since you already changed it i would venture to say it might be a bad connection somewhere. You might check to see if maybe you have a dirty connection or a broken wire some where. The Ohm. meter it going to be your best friend untill you trace it out, you should be able to find what color wires are for what whenyou get your manual.
Old 01-14-2009, 10:27 AM
halffast1g's Avatar
that's what i was afraid of, I will do my best to track it down. Also going to get some pics up, we just painted it too ahhahaha
Old 01-14-2009, 03:09 PM
DRLOWZ's Avatar
Lets see it....
Old 01-14-2009, 09:30 PM
halffast1g's Avatar
My friend has pictures on his iphone. I will try to get him to send them over. We did a $10 rattle can paintjob, which black/white grill paint
Old 01-17-2009, 07:32 PM
halffast1g's Avatar
updated
Old 01-19-2009, 03:18 PM
halffast1g's Avatar
Ok, we I think its the hi/lo beam switch. The horn and the turn signals work, but when i test the high low switch i'm getting no power. New switch is in order for me. thanks for the help guys
C Jacob W
07-29-2013 11:03 AM
mrsmobbins101
05-22-2012 08:21 PM
Stunt'n70f4i
09-06-2010 10:52 AM
Leveltwo
05-26-2007 04:14 PM
Chad_brad
04-04-2006 05:52 PM
Quick Reply: headlight wont turn on
