Head gasket leaking oil
Old Jul 13, 2008 | 10:46 AM
Clorox09's Avatar
Default Head gasket leaking oil
My head gasket is leaking oil on the whole exhaust side. I have a 91 honda cbr f2 35k on it. I have tried a new head gasket twice it still leaks. The head has no warpage at all machine shop checked it out the deck of the block is fine too. I have the bolts torque to 38ft lbs the hanes book says 35. Only thing is i remmeber when i took the head off a washer fell off from that side but there is no spot for a washer at all. The oil is leaking between the head gasket and the head.... Any thoughts. help really appreciated
Old Jul 13, 2008 | 11:18 AM
woo545's Avatar
Default RE: Head gasket leaking oil
Are you sure you got the old gasket all the way off?
Are you sure it's the gasket that's leaking and not the rings?
I don't know if it's suggested, someone else might be able to tell...but maybe using form-a-gasket. to help seal it.
Old Jul 13, 2008 | 12:14 PM
Clorox09's Avatar
The original head gasket is 3 piece all metal gasket so old residue isnt left over. My bike has never burned oil ever. So im kind of stuck at the momment. Is 35 ft lbs not enough?
Fryup2000
Aug 6, 2013 05:43 PM
lawdog850
Oct 19, 2012 04:49 PM
MC_spirited
Apr 22, 2009 10:20 PM
mikeyvis
Jan 17, 2007 06:13 PM
