Gas tank connections. Where does it go?
Hey, So i was wondering why my tank was leaking with a full tank of gas.
And yes, it leaked out almost the full tank until I got back to my garage and put a container under my gas tank. But wondering where this connects to. At the moment, I just plugged it with a little rubber cover so nothing leaks. Where does it go? and why? its a little frustrating not knowing
Thanks,
Tom
Thanks,
Tom
ok, so i know the bigger one from the petcock goes to the carbs, then the other small one goes to the first carb correct? yea for some reason gas drips through there i circled when i fill it up fully... its weird. Hopefully I will not need a new tank. Would plugging it up affect flow of gas to the carbs?
If fuel is coming out the overflow, maybe you don't have a good seal between the gas cap and tank. If you cap it, when it rains or you wash your bike I would think the water might get into the tank.
what do you mean? ill check the gas cap tommrow, as of now i finally got it running thankfully. rode around a little bit but still every so once in a while if i punch it it bogs at high rpms, i did it in first gear it did not bog but then in 2nd in did, but i did it again in 1st gear and it did bog a little bit. like as if its losing power at high rpms. im thinking vance and hines power pak or carb clean most likely
