Fuel Problem?
Old Jul 4, 2009 | 04:56 PM
RunninonMT's Avatar
Default Fuel Problem?
First off sorry for the newb question, im still new to riding and bikes. I just bought a 94 F2 and it was running fine. Now when I ride it, it kinda sputters around 5K rpms. It runs perfect up until then and as soon as i pass about 6K its fine. Its more noticeable in 3rd 4th 5th and 6th. It feels like its not getting adequate fuel but i really done know. Ive tried putting carb cleaner in the gas and it seems to be better for a little while but then acts up again. I dont know if this matters but when its really hot and humid it does this way more. Any ideas or suggestions would be much appreciated. Thanks!
Old Jul 4, 2009 | 08:31 PM
Dissevered's Avatar
If you are mechanically inclined, I would crack open the carbs, clean them while you are at it, and check your jet needles. if they are aftermarket (multi slotted) then I suggest changing the clip position 1 notch to lean it out.
Old Jul 5, 2009 | 11:31 AM
RunninonMT's Avatar
Thanks for your advice. I forgot to mention there's a slip on d and d pipe. do the jets need to be changed?
Old Jul 6, 2009 | 04:28 PM
g32bturbo's Avatar
at cruising or acceleration only?
Old Jul 6, 2009 | 05:24 PM
Dissevered's Avatar
They might need it... is this when you noticed the problem, if so then yes.
Old Jul 17, 2009 | 08:29 AM
BlackLion's Avatar
Ive got this also but more remarkable in first and second gear with constant speed. what can this be?
kwood
Jun 1, 2020 09:53 AM
BitRex
Nov 1, 2015 09:40 AM
Paranoia
Sep 4, 2011 12:26 AM
durty116
Jul 7, 2009 05:38 PM
SVTFire
Aug 29, 2006 07:57 PM
