Fuel problem..maybe??? HELP..
Old Aug 28, 2006 | 01:01 PM
SVTFire's Avatar
Default Fuel problem..maybe??? HELP..
So I finally got the bike runnin, charged up the battery and replaced the fuel...but.. it still has a problem turning over.. it tries too but nothing some times. The only time it will start and run/idle is when the choke is on. when i try an turn off the choke it dies out.. and also when i try and twist the throttle a little, it starts to die... Any ideas...fuel filter maybe??? thanx guys.. (1994 cbr900RR)[image
[IMG]local://upfiles/10334/38830A01F40B4A69ACA6F7C80E44A684.jpg[/IMG]
Old Aug 29, 2006 | 09:21 AM
pacemaker's Avatar
Default RE: Fuel problem..maybe??? HELP..
Fuel filter, air filter is a good place to start, but the fact that it dies when you turn the choke off usually means a carbs need adjusting,
Old Aug 29, 2006 | 07:57 PM
spdrmns's Avatar
either they need to be adjusted or or cleaned.... if that was your first time doing a carb job, you might have missed some jets...
kwood
Jun 1, 2020 09:53 AM
BitRex
Nov 1, 2015 09:40 AM
Paranoia
Sep 4, 2011 12:26 AM
durty116
Jul 7, 2009 05:38 PM
Aweasel
Jun 25, 2008 04:31 PM
