Fuel problem..maybe??? HELP..
So I finally got the bike runnin, charged up the battery and replaced the fuel...but.. it still has a problem turning over.. it tries too but nothing some times. The only time it will start and run/idle is when the choke is on. when i try an turn off the choke it dies out.. and also when i try and twist the throttle a little, it starts to die... Any ideas...fuel filter maybe??? thanx guys.. (1994 cbr900RR)[image
[IMG]local://upfiles/10334/38830A01F40B4A69ACA6F7C80E44A684.jpg[/IMG]
Fuel filter, air filter is a good place to start, but the fact that it dies when you turn the choke off usually means a carbs need adjusting,
