Front Sprocket Positioning
The front sprocket should run closer to the engine case. Think about it this way. 520 sprockets and chains are thinner than the 530 stuff. So when you bolt on a 520 rear sprocket, the center line of the sprocket moves closer to the center line of the bike. If you want your chain to run straight, the front sprocket should then also bolt closer to the center line of the bike which would be closer to engine case.
bowtieboy42
F2 Tech
07-10-2012 03:53 PM
kreush33
05-21-2006 12:28 AM
