Clutch Slipping after Oil Change
Old 02-03-2008, 09:31 PM
benjiboy's Avatar
Default Clutch Slipping after Oil Change
Clutch used to pull to 13k+ without a hitch and now with an oil change it slips at 12k. I used regular Pennzoil 10w30 (or 40...?).
Oil the culprit or unusual coincidence?
Old 02-03-2008, 09:34 PM
Default RE: Clutch Slipping after Oil Change
Is this the same type of oil you were using before the oil change?
Old 02-03-2008, 09:56 PM
SpecR's Avatar
Probably overfilled it. Check your oil level with the bike on the ground, and level (off the stand).
Old 02-04-2008, 10:09 AM
benjiboy's Avatar
I'll check the level, thanks. Didn't know that could cause it. And I've herard conflicting info about how to check it...bike straight up and down as well as bike on stand (sinceon the standmakes the dipstick straight up and down).
Unsure of the previous oil, this was my first change since the previous owner had it. I didn;t know if regular car oil was safe for bikes (but I read on here most people use it).
Old 02-04-2008, 10:58 AM
SpecR's Avatar
Well, it makes it straight up and down, but that's because it's the only way you can get from the clutch cover to the oil pan.
You should check the oil level like it would be when it's actually running. Not to mention the oil pickup is one the bottom of the pan, so there's absolutely no reason to overill it (for lean angle).
Old 02-04-2008, 11:23 AM
kjohnson's Avatar
Get that Pennzoil sheee-attt out of your bike,especially if it's 10w-30.10w-40 Honda GN4 isn't that expensive.
diabloCBR15
07-15-2009 11:15 AM
adams_CBR600f2
06-25-2009 02:46 PM
shopkins
05-04-2009 07:52 AM
sn0rky
05-15-2008 04:47 PM
HighRevver
05-30-2006 06:36 AM
Quick Reply: Clutch Slipping after Oil Change
