Clutch reinstall, no feel in the lever
Old Nov 10, 2019 | 09:40 PM
Harrydog's Avatar
Default Clutch reinstall, no feel in the lever
So i recently replaced the friction plates on my bike. upon re-installation I tightened the clutch lifter bolts until there was no more thread and then snugged them down. the information how much exactly to tighten them down is not available at all and so I went with that after some poking around. Ive followed the manual in terms of reassembly and everything seems to be seated properly. when i put the clutch cover on for test to make sure the clutch worked there was no feel in the lever. after that I backed out the spring bolts and have gotten some feel to the lever. Even after this the when i test it out the bike will shift inbetween gears but when i pull the clutch in first the bike feels as though its not quiet in gear, as if a more frictioned roll than in neutral. This makes me question the position of the clutch lifter plate and the tightness of its bolts. Does anyone know the correct positioning of the clutch lifter plate and how tight the bolts should be (even though there is no torque spec in the manual)?
Old Nov 11, 2019 | 10:38 AM
wes 17's Avatar
Not sure on your model but are there any alignment marks on your pressure plate ?
If it was me I’d strip her down again and reinstall just to make sure I hadn’t made a mistake. I’d double check how many plates I actually have and if they were in the correct order.
I cant help you with values for torquing because I do roughly the same as you. However, I can’t remember ever having my pressure plate anything but tight.
Best of luck mate
Old Nov 11, 2019 | 11:38 AM
Harrydog's Avatar
what would these marks look like?
Old Nov 11, 2019 | 01:16 PM
wes 17's Avatar
Apparently 9ft/lbs for pressure plate ?
i don’t know if you have alignment markers or not. Was your first friction plate different from the others you installed?
2WheelChillen
Jun 12, 2021 08:45 PM
shopro702
Dec 29, 2013 12:14 AM
stunter411
Aug 20, 2013 04:49 PM
hashen27
Jun 11, 2012 09:34 PM
morbidphil0622
Sep 16, 2009 12:12 PM
