clutch disks
Old Dec 28, 2013 | 03:52 PM
shopro702's Avatar
Default clutch disks
worst come to worst I need my bike running to get a better job someone has setup for me. The bike has 8 disks and until I can afford to take it to a shop I need to take a disk and plate out because the lever will not reach the lifter piece. besides doing what your not supposed to do, as long as I tighten the plate bolts is there any real danger? Running off of 7 disks and plates instead of 8?
Old Dec 28, 2013 | 07:48 PM
Conrice's Avatar
I wouldn't. I'm not sure how much more you'll be able to tighten those bolts down without stripping them. On my 954 and 600rr - those spring bolts are essentially bottomed out and then putting them at 9lbs/ft is basically snugging them up...
And with a plate and disc missing, the pressure plate will be closer, meaning you'll actually have less pressure on the pressure plate, and you'll get clutch slippage.
Even if you were able to tighten those springs up more (without them bottoming out and without stripping them), the problem is that it would be harder to pull the clutch because the springs will be tighter..., you're clutch lever is pulling on the springs, nothing else. Tightening them up will make it incredibly hard to pull the clutch lever (even though there is a disc and plate missing).
I don't understand what your problem is though. What lever is not reaching the lifter?
Old Dec 28, 2013 | 09:55 PM
shopro702's Avatar
thanx for the reply.
here is an exact example of my problem I found a few days ago.
Only thing is no one has posted a solution and are long gone to reply.
Everything word for word is what Im dealing with
Clutch basket flush? - Honda Motorcycles - FireBlades.org
Old Dec 28, 2013 | 11:07 PM
Conrice's Avatar
And you have a 929 or a 954? Then that's easy man. Your clutch basket isn't in all the way. The problem is you didn't account for the "scissor gear". Basically, when looking behind the timing rotor on the crank, there is a hole on the crank shaft scissor gear that allows you to take a screwdriver and line up those scissor gears so you can push the basket in the entire way.
Here's a link.
https://cbrforum.com/forum/cbr-954rr...roblem-145573/
It'd be VERY bad news if you rode with it like that. Taking a disc and a plate out would have not helped you at all. You would have just pulled the entire basket towards the clutch cover.
Old Dec 29, 2013 | 12:14 AM
CorruptFile's Avatar
June 2013 ROTM
I had a similar problem on my 600. You need to make sure the drive gears fully mesh. Here was how mine looked:
Takes a bit of fiddling to get it back in. I used bent pliers and leveraged against the case to get the teeth to mesh.
DragonCBR
Apr 6, 2013 07:18 PM
weekendrider
Nov 22, 2010 05:35 AM
Harry_T_Hamster
Jan 15, 2009 07:15 AM
Gladster
Jun 30, 2007 12:57 PM
tb
Sep 2, 2005 06:30 PM
