Clutch cable help
Old 08-08-2008, 10:42 PM
rray12288's Avatar
Default Clutch cable help
Can not figure out how to run the clutch cable. Any help
Old 08-08-2008, 10:57 PM
Default RE: Clutch cable help
What exactly seems to be the problem?
Old 08-08-2008, 11:02 PM
rray12288's Avatar
When I try to run the clutch cable from the clutch to the lever on the handlebar it seems very tight and when I squeze the handle I have squeze it all the way down before I can feel the tension in the cable pulling the clutch. I figured I was just running the cable through the bike wrong.
Old 08-08-2008, 11:16 PM
Iwill take some pics of how mine is routed for you to compare to. Will post in the morning.
Old 08-09-2008, 05:59 AM
eweppley's Avatar
On mine there's a rubber shield hovering over the top of the engine and the clutch cable goes under the frame just in front of the tank, right over top of this shield and then down the right side of the engine just inside the fairing. I've never replaced a clutch cable that didn't feel "tight" and was a absolute bugger to hook up. Also most of your clutch adjustment is going to come from the lower end of the cable. The top adjuster is just for fine-tuning. Hope this helps...
Old 08-09-2008, 12:00 PM
rray12288's Avatar
The clutch cable runs under the gas tank? I am trying to run it around the tank. I bought the bike with no clutch cable so I am just guessing how it goes.
Old 08-11-2008, 12:04 PM
rray12288's Avatar
I figured it out, thanks
Zandaloo
08-22-2013 03:26 PM
fbpsb82
01-30-2010 02:23 PM
lsybert
06-25-2009 11:07 AM
red stinger
07-19-2008 12:17 AM
cyber00677
06-23-2007 06:17 PM
Quick Reply: Clutch cable help
