click-click noise
RE: click-click noise
The CCT will make noise when you let off the gas...the going away as it warms up is pretty indicative of tight valves. with 18K on it, if its never been done I would expect quite a few of them are out of spec.
You can ride it without getting them adjustedbut it will gradually loose power. Its not a cheap job, around 250-500 depending on labor rate in your area and the number of shims required. The job is not impossible to do yourself, but unless you are 3 out of 5 on the mechanically inclined scale, I wouldn't recommend it....not much is required in the way of special tools.
adambowersva
06-30-2009 05:09 PM
