Carb Issues
Old Jul 25, 2006 | 03:33 AM
SikofFalln's Avatar
Default Carb Issues
I recently put a newer set of carbs on my 94 f2 and now the bike will not start. Do I need to prime them? Should I use starting fluid, or just poor some gas into them? This is really frustrating, the bike may not of ran well before but it at least ran.
Old Jul 26, 2006 | 12:09 AM
doublechester15's Avatar
Default RE: Carb Issues
Let me try to help you out and leave some feedback to give me an idea. It may be a vacuum issue. There is a small hose that runs from the left side of the engine block to the fuel valve on the tank, if this is not hooked up or perhaps twisted it will not allow the diaphram in the fuel valve to release. If this is not the case check the obvious like fuel lines. The carbs may also be adjusted improperly. I know from experience because after dismantling my carbs once the bike would not start. I adjusted the three stop screws including the main throttle stop screw and it solved the problem. If you adjust the stop screws make sure to screw them all in completely, and then begin to adjust them all back out equally by counting the number of turns.
mattcossel29
Jun 13, 2011 12:44 AM
97stang
Aug 15, 2009 07:17 PM
electrozinger
May 6, 2009 01:08 AM
hondachris1994
Feb 24, 2009 04:26 AM
stagger
May 24, 2007 07:12 PM
