bondo tank repair
Old Feb 9, 2008 | 06:42 PM
Dj_Squatch's Avatar
Default bondo tank repair
anyone have any tips on using bondo on a tank?...this is kind of a mess and is taking forever....there are 3 spots im repairing..one on the right side lower part of the tank..one on the same spot on the left...and one on the edge of the gas cap ridge thing(this is the one im having trouble with)
Old Feb 9, 2008 | 07:32 PM
radtechrider's Avatar
Default RE: bondo tank repair
Got pics?
Bondo isnt hard to work with. Use the right amount of hardner and work it down while its the consistancy of cheese then let it stand to harden and finish it out. Remove excess with 80 grit then finish out the sanding marks with 160 / 240 grit. Patience is a virtue with body work.
Old Feb 9, 2008 | 07:58 PM
Dj_Squatch's Avatar
yea Im starting to get used to it...this is my first time with bondo on metal...allthough ive done allot of fiberglass and bondo on plastic....its just hard to get that little rim around the gas cap to look right.
Old Feb 9, 2008 | 08:11 PM
SpecR's Avatar
I used bondo on my tank, and it popped off (or rather, it came loose and I pulled it off).
If you have big dents, you're better off getting them pulled out.
OTOH, smaller dents are basically OK, IF you prime and sand the surface first.
Just a warning, I SUCK at body work (I haven't done a decent paint job in my life, but I've done plenty of bad ones).
Old Feb 9, 2008 | 09:24 PM
Dj_Squatch's Avatar
Haha...sounds like you werent using the right kind of bondo...I use the Gold ..its specifically for metal...and as long as your on bare metal and have cleaned it with acetone your all good
Old Feb 9, 2008 | 09:39 PM
SpecR's Avatar
Yeah, I was too cheap to buy Gold... also, I tried to apply it on sanded stickers (I didn't have a strong enough wire wheel at the time).
Also, note to self: don't try to repair fairings with Bondo. You're better off just zip-tieing them or using expoxy (or, plastic welding if you've got the $ for the tool).
Old Feb 9, 2008 | 09:47 PM
Dj_Squatch's Avatar
hahah yea I dont even use epoxy on my fairing...I do fiberglass or bondo putty....bondo putty is great for small rash...for any deep rash that really takes away from the shape I use fiberglass resin. So far my methods for this have been pretty successful, the next thing I would like to learn how to do is carbon fiber...once I get my F4i tail done I may try to cover it in CF and also make a Cf solo seat cowl for it...I am debating making a shell for my tank and using epoxy on it..but I am still warming up to that much carbon lol
Old Feb 9, 2008 | 09:55 PM
SpecR's Avatar
Well, it's ok for rash and gashes, but not for cracks, since it's not flexible.
Old Feb 9, 2008 | 09:59 PM
Dj_Squatch's Avatar
yea fiber glass is the way to go for cracks
Spadez
Jan 8, 2013 01:42 AM
bucklti
Jul 13, 2011 07:05 AM
Dean0
The Hurricane Saloon
Aug 15, 2009 02:30 AM
mauser9052
Jun 16, 2009 07:04 PM
Cypress_CBR
Aug 7, 2006 12:00 AM
