Another won't start
Old Jul 27, 2008 | 07:12 PM
g32bturbo's Avatar
Default Another won't start
I just bought a 93 CBR 600 and went to start it today and it started fine. I let it idle for a minute then shut it off. About 5-10 minutes later I went to start it again and this time it wouldn't start. It doesn't even turn over. Any ideas?
Old Jul 27, 2008 | 07:50 PM
edwardtn's Avatar
Default RE: Another won't start
Won't even turn over now? Have you checked the fusebox?
Old Jul 27, 2008 | 09:46 PM
Rickracer's Avatar
Make sure it's not in gear: kickstand down, in gear, it will not engage the starter.
Old Jul 28, 2008 | 06:03 AM
eweppley's Avatar
I know this sounds embarassing simple...but did you by chance leave your ingition switch on? I'll admit...I've done it...twice!!!! I've stopped using the ki.ll switch entirely.
Old Jul 28, 2008 | 12:07 PM
lonewolfcbr's Avatar
sounds like a drained battery to me
Old Jul 29, 2008 | 08:10 PM
g32bturbo's Avatar
it was indeed a drained battery. i took it to advance and they charged it. I put it back in and it started right up. Could there be something thats draining it or am I just letting it sit for too long?
Old Jul 29, 2008 | 09:13 PM
edwardtn's Avatar
Motorcycle batteries do not last long in general...a few years normally. You'll know soon if it keeps the charge. A trickle charger is a good investment for conditioning the battery in non-riding seasons.
Old Aug 6, 2008 | 08:32 PM
g32bturbo's Avatar
Default RE
turned out to be the battery.
now i have another problem. after i got the battery recharged, it started so i rode it around. the next day i forgot to turn fuel ON and it stalled. after turning back on i rode home. next day bike stalled three times and now it won't start just turn over. checked petcock, fuel and vac good. pulled plugs, not wet but carbon fouled so I replaced them. will turn over but not start. tried starting with gastank open choke down and little throttle, it stumbled and sounded similar to crap but still wounldn't start.
Old Aug 7, 2008 | 04:42 AM
vallip's Avatar
Default RE: RE
One thing to look out for is that the first thing to stop working if the battery is getting just a bit low is the ignition, you can have a spark on the plugs when you pull them out but once installed and they are working in high pressure they do not spark. Try using jumper cables to your car and see if it wont start then, I'm pretty sure it will.
On the carbon fouled plugs, what modifications have been don on the carbs ? it sounds li.ke you may also need to tune the carbs.
Old Aug 7, 2008 | 10:06 PM
g32bturbo's Avatar
Default RE: RE
tried it today, still just stumbles and won't start. I don't see any mods to the carbs. it has k&n filter and yoshi slip on. i took the carbs off and will take them apart.
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
