'93 600 Fighter project
Old Aug 2, 2010 | 01:52 PM
  #61
knifemaker87's Avatar
July 2011 ROTM
Originally Posted by adrenalnjunky
how much you want for a set of the rearset adapters? I'm just over 6' tall and would love to move mine back and down just a hair.
hey, i could cut you a set of plates for prolly $40 and i would need some dimensions of what you are putting onto the adapters... these were made trying to put the pgs in about the same place as stock, with adjustment in all directions. would you be trying to put on stock rearsets?
Originally Posted by JesseAwesome
Those are prettttttty cool rearset adapters.
I unfortunately have no advice for you. I've not been involved this far into an F2.
I am accepting ALL levels of advice. it is better than none.
thanks for support!
Originally Posted by nitrodude
Damn dude, Way to jump into it!! Looks like you've made a lot of good progress on the engine. I'm still going with my original opinion on that oil cooler...Those O rings dry out, and all that rust in there didnt help lol.
yeah, i checked the o-rings and both sets seem to be okay, but since the head gasket was blown, that is certain to leak, and o-rings would just make that problem worse, but they are still worth replacing.
I will most likly have the head machined flat, and replace most of the wearing internals like rings bearings possibly pistons, cam chain and maybe valves.. alot of it will depend on what i can afford.
thanks for looking guys!
Chris
Old Aug 2, 2010 | 02:50 PM
  #62
nitrodude's Avatar
If you're doing all that, Get the shift kit. It eliminates the false neutral.
Also while you're in there check your shift forks for wear, and your 1st/2nd gear. They wear out the quickest on these bikes.
I hope you have a big wallet...Or bank account! Lol.
Old Aug 2, 2010 | 02:58 PM
  #63
July 2011 ROTM
heh... i have neither and big wallet or bank account, however, i do have patience.
What shift kit? the honda one or the factory pro one? what is it that i am looking for? if i am gonna fork out chas i might as well upgrade it.. you know?
and how do i check for wear on my shift forks? (what are those?) the false neutral is what? see? i am not that smart.. i am just good at pretending =)
Old Aug 2, 2010 | 03:12 PM
  #64
adrenalnjunky's Avatar
LOL- false neutral - I'm assuming that's when trying to quick shift to 2nd and you end up in neutral instead.
I did it yesterday ridding with some buddies - rolled through a yield sign onto a vacant rural road, and stood on it in 1st gear, picked the front up briefly, feathered the clutch, clicked into second and was back on the throttle to try and pick it up there - just to find myself on the rev limiter in neutral instead. Hilarity (for your riding buddies) ensues while your brain tries to figure everything out in the space of 2 seconds.
Happens every so often on the 1-2 shift for me.
Old Aug 2, 2010 | 03:27 PM
  #65
JesseAwesome's Avatar
Actually, he probably means a real false neutral. It happens on these bikes a lot unfortunately, in First to second, and in to third. In my bikes case no mater how hard you jam up on the way to second, you get forced out into Neutral.
Old Aug 2, 2010 | 03:33 PM
  #66
July 2011 ROTM
so you would also reccomend the shift kit? but which one? the pro factory one or the honda one?
Old Aug 2, 2010 | 03:48 PM
  #67
nitrodude's Avatar
I've heard good reviews on the pro factory shift kit.
Havn't tried either, but looked into them.
There was a thread somewhere on here that showed good pics of the shift forks and the gears and what the wear looks like, I'll see if i can find it and link it.
Old Aug 2, 2010 | 03:56 PM
  #68
nitrodude's Avatar
Heres a how to,
https://cbrforum.com/forum/how-mechanical-40/f2-shift-kit-install-howto-65393/
Can't find the exact thread I was looking for, But i will look again later, Im heading out the door to go to radio shack lol
Old Aug 2, 2010 | 07:22 PM
  #69
I have the factory pro "quick shift" racing shift kit blah blah blah...
It's basically just a spring and a gasket for the clutch cover, heh... for $35.
It makes shifts quicker and FAR more firm. It does help eliminate false neutrals, although it takes time to break in, and makes shifting difficult at first. Once the springs in though and set, it does help notciable. It is not a fix however, and if you're serious about running your F2 forever, you'll need to do the fix right.
I am not so sure I'll be running my F2 forever, although I do love it very much.
Old Aug 3, 2010 | 07:14 AM
  #70
July 2011 ROTM
what is the right fix? a new shift star?
thanks
~Chris
