91 F2 engine swap for a F3
Hi,
New to the forums and I did a search on engine swaps and found references to the 93 F2 to the 95 F3 engine swap but nothing for a 91 F2
I am not sure which year the F3 motor is but I wanted to see if it was a easy swap between the two.
Thanks for all the great info I used to own a 91 F2 back in Germany which was Red and White. I just picked up a 91 F2 locally here in Reno and the guy also has a F3 motor which has low miles on it.
I also have a 02 VFR800 for the street and a 05 SV650 race bike. I just finished my first season with the AFM #794
Alan
Alan
RE: 91 F2 engine swap for a F3
I found a 91 for sale in the classifieds that has a F3 98 engine in it so I assume it can be done. I dont want to do a lot of work to get it done
I got the Carbs pulled today on the F2 motor, so they can be cleaned and setup again.
Looking forward to actually getting to ride it soon
Thanks for taking the time to reply
yea it can be done.Bascialy anything can be done.But from the reading i've been doing its alot more then just a motor swap..if im not mistaken you gotta swap the harness and all..but yea i know the feeling i just got a 94 600 and have YET to take it out..weather is ****ty and cold here in pennsylvania
I'm fairly sure that the motor is the same for the 95-98's, I think only the 97 & 98 body style was different. One of the other members who raced F2's said it is worth the upgrade and is a direct swap you can use harness and ecu and the 5-10 HP is a HUGE difference plus it has a much better tranny so it shifts smoother.
