suspension settings?
RE: suspension settings?
I talked to some bike mechanic, he advises me to put in some new progressive springs instead of the old ones. Is this advisable? Will it bring something, or is it too much for this 1989 bike?
hoe much air should i put on it when assembled? i heared between 0,8 and 1,2 bar.
I'm no mechanic but upgrading suspension is one of the best things you can do for any high performance motor vehilce , many people will agree. If you plan on riding aggressively then stifferr springs would be good. I spent many days researching on the net the recommended settings for my older 1996 600F3 and then test riding and it made a huge difference in my ability to corner faster. your weight (lbs) and riding stlye are major factors.
I now have a naked 1990 600f and i am intrested in setting this suspesion up for my riding style and weight also. I don't think there is alot of adjustment!
just a preload screww at he top of the fork. more modern bikes have rebound, damping,and/or compression adjustmets. common sense helps determine which each setting does.
preload = weight settings
compression= travel distance
damping = flow of oil/air in fork to settle the bike over bumps
rebound = spring rate back up
I may be a little off but this is how I view them via mountian bike/downhill bikesettings too!
Hope this helps you or anybody to ride smoother and faster. I know I will consider these setting and adjustments with evey motorcycle I own.
Nick
Nick
ORIGINAL: 89cane
i plan on doing all of this soon and was wondering which wayi should go on springs and emulators can anyone tell me what they use and like or where i could get what they have.
thanks
thanks
