Suspension Settings? - (sorry)
Old Jul 4, 2007 | 01:13 PM
DavidPDX's Avatar
Default Suspension Settings? - (sorry)
I am new to the forum and new to the 900 also and I am wondering if someone can help me get the suspension set up properly? I did a search and found lots of info - but still not sure - so I am sorry to bore you guys with an old topic. I weigh around 215#. Some posts said to put everything as stiff as possible? And I know you are supposed to measure sag and all that - the rear end seems to sag the right amount, but the front forks don't even look like they are moving? They are showing 6 lines?
Just from my first rides it seems like the bike "clunks" on bumps - mostly at the front end. Sorry I am just plain stupid when it comes to suspension.
Anyway - if anyone can give me a quickie set-up so I can have a baseline to go from?
Thanks in advance and great forum by the way - I am looking forward to getting to know this bike.
Old Jul 4, 2007 | 08:24 PM
dinez74's Avatar
Default RE: Suspension Settings? - (sorry)
What year is your bike?
The whole suspension set up can very confusing. Setting the suspension to be stiff as ever is not so accurate. If you are a hard rider and won't miss any twisties then its ok. If not its vice versa.
Try to adjust the dampener where there will be Soft & Hard indication. I believe your front suspension is to stiff and hard. Try to reduce the rings to 3 or 4. It will take time to get a perfect set up.
But if your suspensions are faulty, (Not enough oil, damaged bush, bent, leaking etc) then you can't do much.Its better to send to a qualified workshop to do it properly once for all.
Good luck.
carmike_222
May 12, 2009 11:33 PM
Foxtrot4India
Mar 30, 2009 05:29 PM
HonG
Jul 13, 2006 04:39 PM
Crashbaby
Jul 4, 2006 07:17 PM
600rrcbr05tribal
Dec 16, 2005 05:59 PM
