new clutch, special tools?
Old 09-02-2009, 09:06 PM
cbreric's Avatar
Default new clutch, special tools?
I am considering getting new pressure plates, friction plates and springs for my clutch, any special tools needed? impact wrench or anything? I didn't think so, just not sure if people usually did use anything other than hand tools. thanks, Eric
Old 09-02-2009, 09:37 PM
KongBastard's Avatar
Download a manual, it outlines the procedure. I haven't done it myself so this is all I can say.
KongBastard
Old 09-02-2009, 09:53 PM
thegreenbandit's Avatar
There is a clutch center holder, im not sure how nessary it is, or if it just makes life easyier.
Also I don't think it says in the manual, but you need to soak the friction plates in some fresh oil (same kind as your going to use in your motor) overnight
Your gonna need a new lock nut, and a drill to get the old one off, and a punch to restake the new one.
new gaskets, good torque wrench. maybe even replace the bearing while your at it.
Old 09-03-2009, 09:42 AM
cbreric's Avatar
where is the bearing? I have the manual but was just curious, like you said, about the clutch center holder being NEEDED or just nice to have. and for a drill you mean just a regular battery drill with a good bit? thanks a lot! Eric
Old 09-03-2009, 02:55 PM
It's in the plate with the 4 bolts and springs. There is also an other bearing in the clutch (outer)
The bearing is probley fine, but they sometimes get a lil noisey when there a bit worn out I've been told.
Old 09-04-2009, 12:03 AM
Billistic's Avatar
Do a search in this forum. There were a lot of clutch postings in the last year.
Old 09-06-2009, 12:02 PM
tds94probe's Avatar
hey dude, just replaced my clutch last year. No you dont need the clutch center holder but you will need a friend to assist. When you are ready to remove the clutch basket retaining bolt put the bike in gear and get your friend to hold the rear brake and try to hold the rear tire from moving. If your clutch was torqued properly it should work fine.
Check your clutch basket for play as well. The rivets holding them to the flywheel get worn and loose over time.
Old 09-06-2009, 03:01 PM
cbreric's Avatar
great, thanks!
Mike2609
07-08-2008 08:21 AM
Mike2609
07-07-2008 09:02 PM
captain crash
04-11-2008 02:05 PM
madmike01uk
08-04-2007 06:00 AM
transamlt1man
05-19-2007 12:44 PM
Quick Reply: new clutch, special tools?
