Special tools for carb sync?
Old Jun 25, 2007 | 10:26 PM
captain crash's Avatar
Default Special tools for carb sync?
I have a 97 F3. Is there any other "special" tools I will need to do a carb sync myself besides the vacuum gauge Carb-tune tool? Dealer is charging at least $84.
Thanks in advance.
Old Jun 25, 2007 | 10:32 PM
Default RE: Special tools for carb sync?
Also, has anyone used the Motion Pro Economy Carb Sync Tool ($50)?
Old Jun 26, 2007 | 12:09 PM
Sproutf3's Avatar
Registered Users
a set of vac gagues, and a phillips head screw driver dont mess with it unless you know what your doin some times its one of those if it aint broke dont fix it situations
Old Jun 26, 2007 | 12:52 PM
Tahoe SC's Avatar
the motion pro one is fine...
i use morgan carbtune II...it's bling but it's probably the best out there. uses steel beams instead of liquid.
Old Jun 26, 2007 | 08:40 PM
Nauree's Avatar
check this tool out
Old Jun 27, 2007 | 01:11 AM
Thanks for the feedback. Regarding the $4 Carb Sync tool.....has anyone actually used ittuning aCBR? How does that tool get used with a 4 carb system, especially when the No 3 carb is the reference? Thanks again!
Old Jun 27, 2007 | 01:14 AM
Nauree's Avatar
I gona do the self made carb sync soon. All you do is plug on end of it in the reference carb and plug the other in another, sync the carb and move to the next one. All you need to do is keep one end on the reference and the other end is your test subject.
Old Jun 27, 2007 | 12:24 PM
Tahoe SC's Avatar
Nauree...if only it was that simple! when you adjust one carb/tb to sync the reference one, all of them will move somewhat. while it can be done, it's not just a simple matter of moving on to the next, etc...you'll need to go back and check the others to make sure they're still in sync....that's all for now...
BYE BYE BYE....muhahahah get it? in sync...en sync...ah...nevermind.
get this though...once you understand the concept of how a carb sync tool works...it's very easy to make one for much under 10 bucks!
Old Apr 11, 2008 | 02:05 PM
DuDuTzu's Avatar
how about this sync tool, is it good enough, did anybody used before?
DuDuTzu's Avatar
http://cgi.ebay.com/ebaymotors/Carbu...spagenameZWDVW
compster
F2 Tech
29
Jun 5, 2012 12:28 PM
kellybarrs
Jun 6, 2010 07:02 AM
cbreric
Sep 6, 2009 03:01 PM
Mike2609
Jul 8, 2008 08:21 AM
Mike2609
Jul 7, 2008 09:02 PM
