Idle speed
Old Feb 6, 2008 | 07:41 PM
david_ozey2002's Avatar
Default Idle speed
So I'm still working on this 89 600f I just bought, hasnt run in 6 months(maybe bad fuel). Fuel pump is dead supposedly. but it should still run, bad but still run I would think. I checked all elec except coils. Bought a new batt and it sounds like it wants to run but once you let off starter it dies few seconds later. I'm asking about idle speed screw cause preveous owner turned it back and forth when we were trying to start it with a bad battery. Any ideas on where to go from here?
Old Feb 6, 2008 | 09:25 PM
Gogar's Avatar
Default RE: Idle speed
If you can't keep it running with the throttle, the idle screw won't help you. I'd look elsewhere. Are you using your choke at all?
Old Feb 6, 2008 | 10:28 PM
I tried with and without choke. Someone from here give me a haynes manuel online but its kind hard to read. I can continue working with the fuel screw.
500tie
Mar 6, 2013 11:01 AM
Pistol_Pete
Oct 21, 2009 01:53 AM
Mako
Apr 23, 2009 08:05 AM
Jaybird180
Sep 24, 2007 01:42 PM
geoffb2003
Jul 8, 2007 07:19 AM
