it has a hard time reving past 3,000rpms
Old Aug 3, 2011 | 02:10 PM
tripicana's Avatar
did you bench sync the carbs before you put them on?
the manual explains how to adjust the throttle plates before you install on bike.
Old Aug 7, 2011 | 01:53 AM
Halfpint's Avatar
Possible Vacuum hose disconnected at the number 2 Carb manifold vacuum hose for Synchronizing the carb.
Old Aug 8, 2011 | 04:21 PM
tds94probe's Avatar
There arnt vaccum hoses. They are screws that you have to remove and replace with fittings to put the hoses onto.
Old Aug 31, 2011 | 09:03 AM
zophar's Avatar
Mine was doing this and was lean on the crossover from pilot to main jet. Took a lot of time tuning it and when the weather warmed up it was off again. Just a little stumble. But its a rocket it should be running 4k rpm or better unless youre lugging it.
itgbudeev
Sep 9, 2009 10:32 AM
eviljoint420
Jun 15, 2009 08:32 PM
TMcNally954
Aug 6, 2008 01:15 PM
Brennan
May 24, 2007 05:16 PM
MojoWrangler
May 21, 2007 03:26 PM
