generator ???
Old May 25, 2006 | 08:12 AM
eddie v twin's Avatar
Default generator ???
Hi guys , left the cbr 600 standing for a while result flat battery, any way charged the battery up too 12.8 started her up no problem. But !! there seems to be a very low charge coming out of the generator to the battery , rev the bike and theres no rise in charging. Switch everything on the volts drop to 12.1, switch everything off and the volts rise to 12.8 ( just battery recovering ???). Put another reg/rec on the bike still no change. Rev the bike and the volts just seem to stay the same across the battery, thought running the engine would draw off the battery gradually flattening it. Any ideas ??? or is it me ??
Eddie ( I hate electrics !!!!!! )
Old May 25, 2006 | 12:25 PM
rrasco's Avatar
Default RE: generator ???
if you already tried the reg/rec then test the stator too. if you have a clymes manual there is a very detailed section for testing both of these.
Old May 25, 2006 | 01:37 PM
hi havent got acess to a manual, but i connected my meter across the generator out put wires (yellow ones) with the meter switched to resistance. and the reading i got was o.oo on all of them
Eddie
Old May 25, 2006 | 04:15 PM
rrasco's Avatar
i dont remember what is was supposed to be. i do remember you are supposed to check for continuity between the yellow wires(3) and the battery. i have a manual and will see if i can get pictures of it later, or ill scan it here at work tomorrow. that way you know what to check.
Old May 25, 2006 | 05:58 PM
cheers mate your a diamond
Eddie
Old May 26, 2006 | 12:18 PM
rrasco's Avatar
****, sorry dude i forgot, but im going home for lunch and ill get it done then. around 1ish
Old May 28, 2006 | 06:59 PM
Well i finally sorted it out, alternator ok, charging coils ok, regulator ok, battery ok. Turns out it was a corroded connection on the starter solenoid where the live feed goes in ?. Weird though as the bike still started and ran ok just stopped charging up the battery. So i put a replacent 400 one on I had lyeing around, cut off the block connector and replaced it with individual electrical spade connectors on the 4 wires going in ( red/white, red, green, yellow). Started her up and straight away 14.8 volts !! jobs a good one !!. Only took me 2 bloody days to find it !!!!!!!!!
thanks for all your help guys
Eddie
Old May 30, 2006 | 12:45 PM
rrasco's Avatar
sorry i didnt get the manual up for you, been bloody busy here at work, but glad to hear you got it up and going.
Old May 30, 2006 | 04:49 PM
no problems mate, its all sorted now
Eddie
coldflood
F2 For Sale / Trade / Wanted
Mar 7, 2014 06:53 PM
fire4330
May 11, 2010 05:04 PM
rudie
Dec 30, 2009 11:14 AM
cbrmeasap
Aug 23, 2009 02:29 PM
4agemister2
Oct 18, 2008 10:55 PM
