Cam Pulse Generator
Old Aug 17, 2009 | 08:06 PM
cbrmeasap's Avatar
Default Cam Pulse Generator
There is oil leaking from where the cam pulse generator (at least that's what I think it is according to the service manual) bolts to the motor. Is this a big deal or should I simply tighten the bolt(s) and call it good?
Old Aug 17, 2009 | 10:31 PM
bwayers's Avatar
there's an o-ring on it
it might need replacing, but i'd check to make sure the bolts are tight as you mentioned
Old Aug 18, 2009 | 06:44 PM
cbrmeasap's Avatar
Roger that.
Thanks.
Old Aug 23, 2009 | 02:29 PM
cbrmeasap's Avatar
Well there's only one bolt and it was definitely tight.
That must mean the o-ring is worn out. The cam pulse generator is one part, including the wiring pig-tail.
Can I just get a new o-ring or will I need to get the entire new part??
coldflood
F2 Tech
Aug 5, 2011 08:18 PM
sandrailman
May 13, 2011 11:14 AM
jestr
Aug 14, 2008 10:48 PM
Macgomez
Mar 19, 2008 08:44 AM
nrecore0223
Mar 8, 2008 10:27 AM
