Cam Pulse Generator
Old 08-17-2009, 08:06 PM
cbrmeasap's Avatar
Default Cam Pulse Generator
There is oil leaking from where the cam pulse generator (at least that's what I think it is according to the service manual) bolts to the motor. Is this a big deal or should I simply tighten the bolt(s) and call it good?
Old 08-17-2009, 10:31 PM
bwayers's Avatar
there's an o-ring on it
it might need replacing, but i'd check to make sure the bolts are tight as you mentioned
Old 08-18-2009, 06:44 PM
cbrmeasap's Avatar
Roger that.
Thanks.
Old 08-23-2009, 02:29 PM
cbrmeasap's Avatar
Well there's only one bolt and it was definitely tight.
That must mean the o-ring is worn out. The cam pulse generator is one part, including the wiring pig-tail.
Can I just get a new o-ring or will I need to get the entire new part??
coldflood
F2 Tech
08-05-2011 08:18 PM
sandrailman
05-13-2011 11:14 AM
jestr
08-14-2008 10:48 PM
Macgomez
03-19-2008 08:44 AM
nrecore0223
03-08-2008 10:27 AM
Quick Reply: Cam Pulse Generator
